121 - 140 of 4,165 Posts
Discussion starter · #122 ·
Discussion starter · #123 ·
"My" other truck.
200490
  • Like
Reactions: heavydoc
I see a jackpot on there Jake
& I see SHERIFF on the other trucks
Discussion starter · #126 ·
Not sure if it's a shadow or I'm seeing a 4x4 front end there.......
If you don't mind me asking, are you Sheriff's Dept or Border Patrol?
Yes, it is an all-wheel drive, duellies on the back, boatloads of power, and is the Cochise County Mobile Communications Unit.
We were supporting a Search and Rescue mission that night.
Discussion starter · #128 ·
That is awesome, are you volunteer or employed with them?
Volunteer - Our current Communications Leader wants to retire and I am in training.
Unfortunately for me, he is a legend in this State, knows the County like the back of his hand, and has the entire frequency spectrum in his head. I have some awfully big shoes to fill.
Discussion starter · #130 ·
'08 Diff Cover and refill done. I went with AMSOIL 75-140W.
200491
Discussion starter · #131 ·
So -- Would someone please identify this part? It was sitting on the cowling on th driver's side.
200492
200493
Discussion starter · #132 ·
What to do about this disaster? What is it?
200494
Jax,
First one is the crank case breather cap... bolts to the top the the drive side valve cover. The rubber tube then hooks up to the intake. Second item looks like your A/C condenser coil - buy a new one from rock auto or somewhere.
Cj
Discussion starter · #135 ·
I have part of my exhaust out. I am concerned about the Jamo hangers. My hangers come up and then a 90 degree bend. Not the Jamo. Also, the stock hanger has a "penis head" on it, so it won't slide out of the hanger. The Jamo does not. Does anyone have a picture of a Jamo installed in the hanger under the truck?
200495
200496
I put one in my dads dodge and I just slid them in and clocked it so it pointed down a little. Hasn’t been an issue.
  • Like
Reactions: Jax
Discussion starter · #138 ·
Thanks, that is good to know.
Discussion starter · #139 ·
What does the stock air intake / filter look like?
I have a hunch I have a K&N on mine.
Discussion starter · #140 ·
Well, I absolutely cannot get one of these shorter hangers to work. If I do force it in all the way, it holds the exhaust pipe against a heat shield bolt. :mad:
