Status
Not open for further replies.
Would this fix the T/C unlock during braking issue?
10K views 28 replies 12 participants last post by  matthewd11
#1 ·
What has to be one of the most annoying issues I have with my truck is that the torque converter unlocks whenever the brakes are applied. The unanimous fix for this seems to be to install a manual override switch to keep it locked. I have noticed however that if I coast to a stop, without touching the brakes, the converter will stay locked until the vehicle speed reaches ±25mph. Based on this, I assumed that since the PCM controls converter lock up that it must also be receiving a brake light input. As a test, I unplugged the harness from the brake light switch on the brake pedal, disabling the brake lights, and went for a drive. During this test the converter stayed locked, with the brakes applied, until the speed had slowed way down. I took a look at the wiring diagrams for my truck and there is a wire going to the PCM that provides the brake light signal input. The next question then is what else does the PCM use the brake light signal for? The wiring diagram shows that the cruise control, rear stop lights, high mount stop light, trailer brake control, shift lock actuator, and rear anti-lock brake module all receive their brake light signal outside of the PCM.
Unfortunately, there isn't an easy way to unplug the wire to the PCM. Would have to either de-pin it at the PCM connector or cut it. Before trying it though does anyone know what else the PCM uses the brake light signal for? I'm also thinking that removing the brake light input from the PCM would solve all the issues with the converter not locking when a brake light bulb is burned out or when they are replaced with LED lights.
I am assuing that this torque converter issue can also be fixed with a custom chip. Is this true?
Thanks,
Shawn
Save
#2 ·
Who says it's an issue? :poke: I use that feature to get better fuel mileage...
Ok, ok, if you don't like it, you can have it written out in a custom chip. they usually only do it in a tow program, but they can do it in any program.
I would NOT de-pin or disconnect anything from the PCM, but that's just me.
Save
#10 ·
i believe it'll actually get WORSE fuel mileage if it unlocks while slowing down... it seems like while slowing down it throws in BARELY any fuel at all... just enough to keep the engine running... but when it unlocks it has to throw in enough fuel to keep it idling, with no momentum keeping the engine spinning with the TC locked... if i watch the PW on my scan gauge (not the best indicator for this) it'll never go above 0.4ms if the TC is locked while slowing down... if i let it unlock it goes to 1.0-1.1 for a couple seconds when it first gets to idle then drops to like .8 i believe... not really sure cause it's been a little while since i payed attention to that stuff... just my $.02
Save
#3 ·
LED brake lamps will cause the same issue. The same with the ABS sensor in the differential case. Any added resitence in the wiring as well, the computer reads voltage through those systems for converter lock up.
Save
#4 ·
Yes a chip will fix it, or getting your computer reflashed to the TDE1 code, which has much better shifting and TC lockup and holding.
Dave
Save
#13 ·
3-StarJ.R. said:
Like Dave said the TDE1 stock calibration has much better TC lock logic. If yours is already a tde1, and during deceleration you have touched the brake and the tc unlocks but you want it to kick back in, just blimp the throttle and it'll lock back up down to the stock mph unlock speed....
AZStang said:
Yes, I have the TDE1 calibration. BIG improvement over what my truck came with. Just seems like it should stay locked down to a certain MPH instead of coming off with the brakes. Also like I said, with the brake lights unplugged at the pedal, it performed perfect. I may play with it more when I get some time, but it sounds like the real answer is to get a chip.
Sorry, Shawn. The bad news is that there are no 94.5-97 PCM codes that actually allow what you want. A new chip will not solve your problem, no matter what box code base is used. TDE1 is as good as it gets as far as torque converter use is concerned.
#5 ·
#6 ·
Shawn
Save
#8 ·
Heck I am looking for a tune where it lets the convertor un-lock on a downshift if the brake is not applied.
Tom
Save
#9 ·
What exactly do you mean? The converter to unlock to be used like a downshift or the converter to unlock simultaneously with the downshift?
If the later that's going to be a huge RPM jump.
Save
#16 ·
Not only that, but the PCM may be commanding .4ms of pulsewidth....but the injectors take 6-7ms to actually open because of the armature/solenoid/plunger action. That's why you don't hear the injection events during decel at RPMs above 12-1300.
#20 ·
Thanks, I got it now. Are you positive the PCM uses the brake input to cancel the cruise? The wiring diagram shows the "brake lights on" signal going to the cruise control outside of the PCM. That switch on the front of the master cylinder is also used to cancel the cruise.
If the cruise is canceled outside the PCM, the idea I have of removing the brake light input to the PCM may just work. And potentially work better than forcing the T/C to engage with a manual switch outside of the PCM control. If this mod works, the PCM would maintain full control of engaging and disengaging the T/C. The only change would be it wouldn't disengage when the brakes are applied. Probably put a switch in line too.
With regards to the "which option would save the most money discussion," there would be less brake lining wear with the converter locked.;)
Shawn
Save
#21 ·
I would like the convertor to just momentarily unlock on a 4-3 or 3-2 downshift. Something to ease that up a bit.
Save
#24 ·
Actually the time when it annoys me is when you are just slowing down enough that it shifts on its own in basically a coast mode. Under power it is better.
Tom
Save
#25 ·
You could probably have your downshift point changed (lowered) when there is no throttle input so that it doesn't downshift so early and then you would never know that the TC is staying locked since the RPM rise at downshift is in such a low RPM range.
Save
#28 · (Edited by Moderator)
.i search for threads pertaining to issue i mite be having and read for solutions i posted because i have a 94 f350 7.3 idi auto trans that every time i let up off the throttle it felt as if od was coming out or was shot or burnt up in my trans and after it taking 2 months of research i discovered in a thread that another man asked if tach would drop to 0 when u let off of the fuel....then he went on to say that speed sensor working cause speed odometer says 45.mph and when faulty tach dropped to 0 the pcm was figuring truck is doin 55 in drive and truck not running cause tach says 0 therefore pcm put trans in limp mode so would not tear trans out.
Status
You have insufficient privileges to reply here.
