As was mentioned the earlier PSDs had a Dual Mass FlyWheel (DMFW) setup. It has two masses that are connected together with springs between them to dampen vibration. The problem with them is that they are expensive, can't be simply resurfaced when putting in a new clutch, and mainly they go bad from the spings/retainers going bad causing a nasty vibration problem. The clutch disk is solid and has no dampening springs in it as they are located in the flywheel. The clutches are also very stiff and require considerable pedal effort. Replacing both the clutch and flywheel with stock stuff will run $1100-1200!
The Single Mass FlyWheel (SMFW) kits will usually come with a single piece flywheel (more like everyone is used to), clutch plate, clutch disk, anf throwout bearing. The clutch disk now will have the dampening springs in it vice the flywheel (more traditional). The clutch has a larger diameter, lighter pedal feel, but more low RPM gear rollover noise (bothers some folks, but most live with it for the other advantages (incuding much less cost).
I went with the SBC Con-O on mine and have been happy with it. There are plenty of folks that like their Luk, ValAir, SBC, or Valeo. Cheers!
