Ive been seeing alot of these cracked piston issues lately..does anyone know whats causing it? bad injectors? faulty pistons? bad tuning/excessive cylinder pressure?
Agreed, cryogenics does wonders with cast and forged pieces.I think the cryogenic process would be invaluable and also
From what I have seen it seems to be a few different things that lead up to them. The two big ones that I can see are high back pressure and high egts causing the piston to thermal grow and cool more then they are suppose to.
In other words when people buy these big 300+ tunes and run the EGT up north of 1600 degrees the pistons get small cracks in them from the thermal growth. Over many many times of doing this the piston will crack.
If you have supporting mods like EGR delete and extrernal wastegat I truley belive ass long as your not hold high EGT for long period of time the pistons should last longer then most things on the truck.
Of course when a injector sticks and that piston is getting unmetered fuel that going to do some damage also. QUOTE)
I dissagree. Every cracked piston I have seen was not related to abuse or high EGT's unless it caused a stress crack which did not let go until 20,000 Miles after the abuse, The back pressure is not a concern either on a non spray truck the EP is regulated by the VGT turbo and does not get high at all
