I've had pretty good luck with mine as well. But I have run into a few things over the years.....bought new in '03 now has 140k.
-Front brakes at 100k, new rotors, if you touch the brakes make sure you lube the piss out of the caliper slide pins.
-HPOP o-rings, if you start leaking oil check the valley on the engine
-Starter replaced mine at 90k, bolts were loose put some lock-tite blue on them no problems since.
-Bushings on the drop links for the sway bar, replaced with poly ones. Heat them up beat the piss out of them to get them out or find someone with a good bearing press
-O-ring for the dipstick in pan. Notorious leak point, haven't replaced mine yet but here is a good link to show how it's done.
Oil leak at dipstick tube flange fixed -with pics! - Ford Truck Enthusiasts Forums
-Carrier bearing for drive shaft, replaced under warranty
-Up-pipes leaking, another common issue. You can simply replace the donut gaskets (what I did). Or go to the bellowed style up-pipes, DI makes a good set and so does International (wish I had the coin at the time to do this).
-CPS never really had any issues with mine. I keep a spare in the glove box with a 10mm (I think) socket.
-Water pump at 110k. The fan can be a bit of pain to get off, but if you got the right tools you can do it in an hour or two. If you have to replace it I would highly recommend doing a flush on the system.....it's in the tech info section on here.
[7.3L - Technical Info] - Powerstroke Nation
Spend some time looking around in there. Lots of good information.
A lot of good folks on here to help.
Welcome to the Nation!!
