Symptoms of bad IPR
2 reading
88K views 14 replies 9 participants last post by  07_powerstroke
#1 ·
What are the symptoms of a bad ipr? I'm working on an 03. It has been hard to start after it gets hot for a while. The other day it lost power and then cut off and would not restart. I have already changed the icp sensor and the hpop because they had already gone out. It had several codes the only new one said ipr circuit open. Sorry I didn't get the number.
#3 ·
mine lunged. It would fuel up the motor and raise the RPM 400-600. But I think mine was an out of the normal symptom
#10 ·
Its a solid piece on 03-04 isnt it????
#13 ·
Does it have the EGR deleted? My parents 04 6.0l would idle fine but when ever you would touch the gas pedal it would not move. The EGR valve was all full of carbon and sticking open. When you first start the truck the EGR valve open and close as part of the system start up.
Take the 10min and check the EGR valve.
Mike
