Running a 2.5" Leveling kit without the caster adjustments
1 reading
17K views 30 replies 15 participants last post by  Slick Willie
#1 ·
Anyone have tire wearing issues without running the caster adjustments when installing the 2.5" spacer.
I am fine with how it drives, the steering wheel doesnt even seem off much, so I will correct that myself and toe seems fine. I see no reason to get an alignment but I was just curious how many dont install the caster adjustments and tire wear is normal.
#2 ·
you should at least have the alignment checked. i did alignments for 6 years at my old job and did a few on leveled trucks and caster was never very far off even without the adjustments.
i am running the 2.5" Ebay lift spacers on the bottom of the spring and havent needed an alignment. i did have to correct the steering wheel but that is it.
caster will not cause tire wear at all. the angles that will are the camber (not likely to be out) and the toe, which is most likely the cause. another MAJOR part of reducing tire wear is keeping them rotated EVERY 5K miles! taht is the main thing most people overlook and it kills a tire to stay in the same place for long periods of time
can you tell i work for a tire company??????
#3 ·
I went plenty miles on the toyos before selling the levleing kit to you and it never wore a tire funny at all....But as said above you will have to adjust the steering wheel.
#4 ·
perfect thanks! i was pretty sure it wouldnt from past adjustments on my ranger but I never run that on the road long enough to know. I'm not too worried about toe or camber. Steering wheel is a simple fix.
I like the way it came out, just needs a little more lift in the rear.
#9 ·
thanks, I like them too. Should work out well for my needs.
sorry I have never heard of fixing the steering wheel, what entails in doing this? I'm fixing to install a 2.5" spacer kit on my 05 and was just curious cause I may have to do the same if
need be.
adjust the drag link via the sleeve over on the passenger end. IT will need shortened a little when you put the lift kit on.
#7 ·
Castor shouldn't affect tire wear, just how the truck returns to center and how it reacts to ruts, bumps and helps shimmy etc. No alignment required after the shims are installed. If they came with your lift it I would use them.
#10 ·
I didnt get them, it seems to drive fine, I can tell it doesnt react the same as it did but it really doesnt bother me. I am used to driving a truck with bias ply 42s.
#13 ·
they are a 35x12.5x20, you were close Jeff.
I think I would like to get some F350 blocks though. I have read some people say to get them at the dealer? How much are we talking?
couple more pictures too
#14 ·
You can get F350 blocks at the dealer for around $100 but you will have to go to a spring shop to get the U bolts because the dealer doesnt carry them.
I did this on my 03 F250.
#15 ·
#20 ·
No I didnt. Id like to buy the ready lift adjustment but I probably wont for a few months.
The truck looks great, just what im looking for. Is the install something you can do yourself?
Yes it is fairly easy if you have jack stands and a jack. 21, 18, 15 mm sockets.
The rear is about the same to switch out the blocks, you just need a 15,18,21 and 24mm sockets.
#22 ·
I'm not really either. Anyone make there own radius arms? I was thinking about making my own adjustable radius arms. I think I could make a 4 link fit too, but that would just be extra money.
#24 ·
No I dont, It is noticeable if you are looking for it but it doesnt just stand out. Ive read its 1/2" to 3/4" to the drivers side. So its not much really.
#26 ·
Yeah I measured 1-7/8" on the stock F250 blocks, I have some aftermarket "3" inch blocks that measure 2-7/8" my only complaint with those is they dont have the bumpstop in them.
#29 ·
The front 2.5" spring spacers are a 1/4" short also..I havn't measured the rear blocks but hardly anything is a true what they say it is size anymore..If that makes sense!!!
#30 ·
yeah that doesnt surprise me any.
anyone running the ReadyLift drop brackets for the radius arms? I was looking at those to correct my caster instead of making new arms. My truck tracks a little bit and I dont care for it. Our roads are so crowned here that isnt helping either.
#31 ·
Truck looks good. I ran the 2.5" front pucks on my '08 F-350 for over 70k, and now I have a new set of 2.5" pucks on my '10 F-350 for over 18k. I never adjusted anything, no alignments, trac bar, steering wheel, nothing and I've never had any issues and my tires have always worn evenly. I rotate my tires in my driveway every 3k though. I think that's the key.
