Today i pulled the rear drums to check the brakes and see about adjusting the e-brake. Well wouldn't ya know it, the passenger side axle seal is leaking and all the shoes are cracked.
Ok, I call advanced and they have everything I need. I Go pick up the parts and tear into the passenger side 1st.
Pull the axle bolts, axle, wheel bearing nut and outer bearing. But now the spindle is fighting me. After a lil more pulling i get it off. Well half the seal is on the spindle and the other half in the hub. I manage to get the "wear sleeve" off the spindle and can see why it was on there(the spindle is quite pitted)
Anyway i pull my new seal(national#370047A) out of the box and it is just a 1 piece design(not going to work)
So my question to all of you is, where do I get the 2 piece seal like the one I took off? Advanced cant get the 2 piece one. And does anyone have a write up on how exactly it goes together?
thanks,Brad
thanks,Brad
