Hi all! I'd first like to thank everyone who posts on here for already providing me with good advice in going through back posts.
This here is my PSD, I've been running it for about 6 mo. now, and it's got about 150k on it. The motor looks pretty much original with a new Jasper trans that works well. Motor is totally stock, and I'm the first private owner- truck's a retired Time-Warner rig that I got through a dealer from the auction.
The problem I've had since day one with it is that it's always started really hard when cold, and had a definate dead cylinder until the temp gauge hits halfway up, at which point it starts hitting on all eight and runs well with good power for stock. I will say that it does have a slight miss if you rev it or hold some rpm in Park, though. If you floor it in Park it revs to about 2,500 and starts breaking up and blowing grey, but it pulls well to 3,200 or so when driving.
I've replaced 7 of the glow plugs as the rear cyl. on the pass. side (#7?, #8?) has the tip broken off in the head and someone has welded the top of the GP closed turning it into a pipe plug. This made no difference in the hard starting. GP relay is working right and powers them for up to 120 sec. I've never had it throw a CEL. Also, I have a hell of a time getting this thing started at anything under 50*F outside temp. Most times I have to plug in the heater for 1/2 hour, and then it fires right up, always with the miss.
I noticed that I had different colored injectors (some black, some tan) when I did the GPs, but I failed to jot down the part #s or codes when I had the VCs off. Rookie. I'm suspecting a bad injector for sure in at least one hole, and since this thing has some miles on it, I'm thinking a matched set would be the way to go. My question to y'all is this:
Which is the right way to go here? I want to get more power out of it, but I don't want to do DIYs since I'm not starting with good injectors. Should I get a set of stage ones? Hybrids? ACs? Have mine rebuilt/modified? As soon as I get this running/starting right, I'm gonna get a power package with a TW chip, 4" or 5" exhaust with DP, intake, and gauges.
Any advice on choosing the right path to happy, powerful injectors would be greatly appreciated. I've seen the name Jim Rose mentioned quite a bit- anyone know how to get in touch with him?
Thanks in advance,
Justin:doh:
Thanks in advance,
Justin:doh:
