I just did it on my truck this morning.
Man that mobil 1 is pricey, 10 dollars a quart, bought three, but i think it would have been better with four...
everything went fine, very easy, didnt lift my front end up, but i got a great calve workout from pulsing the brakes!
i do recommend you tape or plug the open end of the return line, it started spewing even though I had it up and out of the way.
I have one concern, when i put the return line back on, with its clamp, it felt like i could easily pull it off, i think im going to run to the store and get a small screw on hose clamp. all that fluid made it very slippery.
I used:
3 quarts of Mobil 1, synthetic auto trans fluid, though i should have bought four
6 feet of 3/8" inner diameter tubing, its the perfect length for a non lifted truck to be fed into a milk gallon jug on the ground. it was about thirty something cents a foot at lowe's.
and preferrably someone to help, i could have finished in about five minutes if i had someone turning the wheels and pumping the brakes for me!
all in all very, very easy!
