P1316 Injector Driver Module/IDM Code
37K views 10 replies 4 participants last post by  Justin@DP-Tuner
#1 ·
Hi - got my AutoEnginuity Ford Enh. Scanner in the mail today, I've got P1316 IDM code - tmrw I'll pull the fender well apart and hope it's some crusty wire: any tips beyond check for broke/crusty/bad wires/wire harness/plugs before I by an IDM?
2001/7.3/F350
#3 ·
Google fifty cent mod...
I got that code and had a loose connection.
Basically pull valve cover take a quarter cut a flat spot to washingtons hairline stick it in the harness clip to hold up the lock...ford has a shim kit that does the same.
You can start the truck let it run some and scan the exhaust manifolds with an ir thermometer. . 30 bucks or so at harbor freight lowes etc....in my case one side was 100 degrees cooler.
Thus the misfire side.
#4 ·
Agree on running the buzz test...but as stated previously...
IDM codes do not necessarily mean there is a problem with the IDM itself...IDM codes can be caused by wiring, injector, PCM, or other vehicle issues...
basically if the IDM buzzes all 8 injectors (and you, audibly hear them...annnnd they all sound relatively similar in tone)..then the IDM itself is most likely fine.
further...if the vehicle starts/runs without a constant SES/CEL illuminated...then your wiring to the injs is most likely good...assuming it's Ford/Motorcraft wiring & UVC gaskets.
is there a specific issue you're trying to troubleshoot?
often 'codes' may have nothing whatsoever to do with a drive ability concern...but sometimes you'll get lucky and find a correlation.
#5 ·
I had a code and the engine was running like a jumping bean in a tin can..
ok maybe not that bad but no mistake something was very wrong.
#6 ·
intermittent service engine light: on the buzz test: code P1272 Cylinder #2 high to low side open...had a cocktail and a smoke with my truck, will do about anything to it except for changing injectors(front yard wanna be fixer gurl here and the whole fuel/oil mixing - hand crank thing scares me a bit). The buzz test: hardly any audible sounds whatsoever. I watched the youtube world and there is definately audible clicks - I have few, truck starts right up, runs,drives normal intermit. engine light(runs loper mode 1/3 throttle with extra noise)..then engine light clears and all is good. I'm just fearing my bill at Interantional if I take it in
