P0404 and P0405 codes with CEL after EGR replacement
1 reading
12K views 12 replies 4 participants last post by  Hunter66
#1 · (Edited)
Hello,
I have a 2006 F250 with a 6.0 L diesel. I've owned this truck for 6 years and have occasionally cleaned the EGR valve. Yesterday I decided to replace the EGR Valve after noticing the O-rings were breaking and knowing that it was original to the truck. I purchased a new EGR Valve from my local Ford dealer. After installation I am getting a CEL with p0404 and p0405 codes. I scanned the truck prior to replacing the EGR and everything was clear. I also replaced the fuel filters the same day. Any idea on the reason for the CEL and codes?
Thanks for any help
Hunter66
#2 ·
Any chance the egr valve was unplugged with the key on? Also last time I hade those two codes together I was getting an erratic egr position signal, I suppose you could have got a bad part.
#4 ·
Do you have a scan tool that can command the EGR valve to open to verify it's functioning?
#6 ·
I would clear the codes and make sure that connector on the new EGR is seated properly
and try again if it does the same thing I would get new gasket/oring kit from ford for the old one and try it if it has no issues I would be talking to Ford
what did you pay for that ? over 200 bucks ?
#7 ·
Yes, I paid $251 for the new part. Unfortunately I returned my old egr for the core charge. I had to call them dealer and get my old part back and pay the $30 core. Just drove 150 miles with the new egr without issue until I stopped for a few hours. The CEL came back on. If it comes back after clearing I will return to the dealer.
#10 ·
Yeah they started doing a core charge on them about a year ago. Must be replacing too many and running low on replacement parts.
  • Like
Reactions: Zmann
#12 ·
Thanks for the tip on a new parts supplier. The CEL came on again while i was stuck in traffic. I will be putting the original EGR back in tomorrow morning. The only high point of today's misadventure was seeing the Patriots beat the Bills in person.
I am fully expecting to have to fight with the dealer to get a new EGR, they were already trying to say that they need to run a diagnostics on my truck before they will replace or refund.
Thanks to everyone for the help
