oil in intercooler pipe?
8.4K views 9 replies 5 participants last post by  powerstrokin7.3
#1 ·
as the title says I found oil in my inner cooler pipe after the clamp left go and the pipe came off goin down the road. Where would this oil be coming from? the turbo? I have the ccv mod already done
#2 ·
Did you clean the IC tubes after you did the CCV mod?
The oil is more thing likely left over.
#3 ·
the ccv mod was done before I bought the truck, so I don't know if it was cleaned out. How should I go about cleaning everything?
#4 ·
I took all my intercooler pipes off and cleaned them out with brake cleaner but dont clean the boots with brake cleaner as there material doesnt like brake cleaner. You should take the intercooler out and dump the oil out of it to. I took mine out and dumped about a quart of oil that was laying in there from over the years.
#10 ·
thanks guys, I cleaned the pipes out, so ill drive it for a few weeks and if there is oil in it again I think ill just rebuild it. The shaft is starting to get a little play in it anyhow and I don't have the cash right now to replace it, cuz if I replace it im gunna wanna go bigger :evil
