Morning/Afternoon!
alrighty, i've spent about a year reading up on what this might be.
Symptoms:
*Noisy grinding vibration that ONLY happens when turning left under throttle.
*The noise exactly matches engine rpm.
*The noise comes & goes with the pedal troughout the turn, i.e. if i start off hard (noise), let off (no noise), repeat etc...
***This ^^^ is how i figured out it matches engine rpm lol!
maybe/maybe not related, but i smell exhaust in the cab more often when idling & a little bit sometimes while driving.
This has NEVER happened when:
-turning right.
-coasting through left turns.
-takeoffs.
-breaking.
-cruising.
-idling.
So, over the last 9,000 miles of the truck doing this, i just can't see it being a wheel bearing. I need to check them again soon though.
Ford did a lot of work to it before i bought it. Could it be loose up/down/exhaust pipes leaning over & toughing the frame or something???
2006 F250 6.0L, ECLB, RWD, 225k miles, pretty much all stock.
truck has had the cab removed at around 180k miles for a HG job, new egr cooler, turbo, and some other stuff iirc...
I'll be going over the PO's service records again to see if i can figure something else out.
thanks!
Symptoms:
-turning right.
-takeoffs.
-breaking.
-cruising.
-idling.
thanks!
