New injectors no start?
945 views 4 replies 5 participants last post by  blackbetty13
#1 ·
i just put single shot injectors in my truck and ive double checked that everything has been pluged back in. I know that my truck comes from the factory with split shot but i had Elite tune me tunes for singles. If for some reason though they forgot would my truck still start if it is programed for split but has singles. The truck doesnt even sound like its tryin to start its just rollin over and i dont know when i should give up on tryin. So what do yall think the problem is.
#2 ·
how long have you cranked it for? I usually unhook the cam sensor and crank till i get oil pressure then plug it back in and she starts right up.
#3 ·
It should start if you did the install correct. It might take 15 minutes of cranking but it should fire up.
Did you make sure the oil is full both in the crankcase and in the HPOP reservoir?
Keep the batteries charged up. Give it help with some jumper cables or a charger.
DO NOT Over Heat The Starter. 15-20 second cranks and let it rest to cool.
Avoid using starting fluid.
