Hi everybody. Im new to the forums here and hope someone out there can give me some advice. I bought my first powerstroke a few weeks ago and I got it pretty cheap because it ran a little rough and blows whitish blue smoke out the tailpipe.
well...first thing i did was pull the valve covers and sure enough two of the injectors in the passenger side head were not spouting any oil. I replaced the all 4 of the passenger side injectors with new alliant units and changed the oil and now the truck runs waaaaay better. All of the driver side injectors were spouting oil so I figured i'd wait to replace those untill I have some extra cash.
The truck still blows white/blue smoke out the tailpipe from startup untill warm and under accelertion at all temps. There is also some excessive cackle or knock from the injectors under acceleration but since it doesnt make the noise unless the engine is under load i cant figure out what injectors are the noisy ones.
I figure maybe one of the injectors I didn't replace is bad but if an injector is bad will it still spout oil?
Also I read air in the fuel lines can cause smoke and upon inspection of my fuel pump (the one attached to the frame by the tank) the hose that leads to the engine from the pump has some sort of fold-down clip connecter that is broken and the hose is just the littlest bit loose ( it can twist and move in and out on the pumps metal outlet about 1/8) Is this normal and is there any test I can do to check for air in the fuel?
