leveled with 37's
44K views 27 replies 15 participants last post by  zink_m
#1 ·
Im looking at buying some Kuhmo road venture mt's and throw them on a set of bmf novakanes the problem is they dont make a 35 in the kuhmo so if i just level my truck will i be able to fit 37s? I was searching this and someone said that this can be done?
#2 ·
with stock rims you can get by running a 37.. when you add an offset rim it will make them wider, hence harder to clear.. i ran 37 13.50 20 on stock rims with a 2.75" leveling kit and blocks in the back, it was too tight for me, shifted the axle too far, scrubbed and looked too narrow. 6 inches is minimum for a 37, imo, especially with any type aftermarket rim. if you want it to look good and still retain your gas milege,your performance, and part of your wallet, go with a 2 in leveling kit and blocks with 20"s and 35s
#27 ·
i run a 4.5" icon with 37'x12.50's on a stock rim and have very slight rubbing on the radius arm only... 6" is not needed..
#3 ·
you MAY clear a 37 with a leveling kit but you WILL scrub when it turns. 35's are a perfect fit.
why are you stuck on the Kumho's? they arent a great tire and you can get a LOT of 35's that look nicer and ride better
#5 ·
What im going to do is go with a 20x10.5 aftermarket rim and some 35s then. I see you can just get a 2.5 spacer for 135.00. Would this be the way to go? What is everyones suggestions on a m/t 35 to go with?
#12 ·
i love my nitto mud grapplers on my 3rd set on this truck. strongest tire ive ever ran, only downsides are they suck on ice. some people hate the noise but i dont mind it. i get 30k to 35k out of mine
#7 ·
Here is my old truck, 2 inch spacers in front and factory f350 blocks in the rear. 35/12.50/20 toyos on 20x10 wheels.It was a nice fit.
#8 ·
I should be able to tell you if they fit pretty shortly. I just ordered 37x12.50 on a 20x10 4.5 bs W/ -24 offset. All I have is the leveling kit. Wheels and tires are supposed to be delivered on Friday but I am going to be out of town all weekend till next Tuesday so I should get them on Wednesday. I have researched this quite well and I am pretty confident that it will work, the only thing that I am not sure about is the offset.......... Nothing like trial and error.
#10 ·
i dont think it will work with that offset either, mine is leveled with 35's and my 20's have a -44 offset and i rub. but you may get lucky
#9 ·
That offset probably wont work. I just did a friends 08 with that offset and 35s and did plenty of trimming to make it work.
#13 ·
where is the best place to get spacers to level the truck? should i got with a 2 or 2.5 inch spacer on an f350? The tires ive decided on are cooper discoverer stt 35x12.5x20 with 20x10.5 Does that sound like a good setup?
#15 ·
i cant remember but i think its 4.5 they are jesse james widow wheels
#17 ·
2.5 leveling kit
thats the same one i'm using. same as the BMF without the name on it. and at only $26 you have some extra cash.
i didnt need shock extensions either
#20 ·
leveling kit #2
they just came out with this kit. VERY complete. i actually emailed for the track bar spacers for my lift!
#24 ·
also curious to see the pics as thats what im looking to. put 37s and novakanes on my leveled truck.
