Ok I posted about this in another of my threads but thought it deserved a new thread.
Some background 04 6.0 (03/04 build date),151,000 miles, SCT X3 with Spartan Hybrid Race tune on, new FICM reading 48.5 volts cranking and running.
I got my scangauge II and plugged it up and went to monitor a few things, my truck seems to have a mind of it's own on starting the past few months (it runs great but every few weeks it will just up and not start) Anyway when the truck was warm, it had recently ran, while cranking the duty cycle, IPR, read 27-28... at idle it sits around 22-23 and ICP is at 600 or so.... I also measured at full throttle ICP was very high close to 2000 (could have been more, I was more concerned with watching IPR) IPR at full throttle was 70.
Today I did the same thing to check it, I started the truck cold,... ICP looked ok, but IPR duty jumped to 50 while cranking (still at 22 idleing)... Continued to do the full throttle check and again it jumped to 70 or so. Drove the truck about 1 n 1/2 hrs parked it then started it back up 10 minutes later IPR duty while cranking was right at 29-30....
If anyone can give me any info or help that would be great... Why do I get different reading when hot crank or cold crank? Do I possible have an HPO leak? I have no DTC's and everything seems to be ok. The truck has been running without a hiccup for about 3 weeks now.
