Yeah read about the split shots and I understand they release a smaller shot then they release the second shot of fuel required.
Split-shot injectors were originally installed on 1996 and 97 model/year trucks with California emissions, and are used in engines from 98.5 on. These injectors prolong the injection time to decrease emissions without reducing power. Fuel is delivered to the injector past a check valve in the same manner as in the standard injectors. As the intensifier piston is forced down the fuel is pressurized and the check ball is lifted off its seat and fuel injection begins. Cut into the piston is a land which receives fuel through bleed holes as it is pressurized. As the piston travels down the land aligns with a port in the injector. When this happens, pressure drops below the piston and the check ball reseats and injection is suspended. As the piston travels further, the port in the injector is covered and fuel injection recommences.
I am just trying to learn a little more about what is under my hood and what will and will not work with it. What the differences are between the injectors that are basically from the same engine platform just different years. I'm a Small Block Chevrolet man and a small block Chevy is pretty interchagable don't matter if it's a 1968 350cui or a 1983 350cui engine. Sure there are differances but you can swap parts pretty freely with them.
Now what I'm wondering is on the AB Injectors is the Pre shot a seperate signal from the IDM then a second signal from the IDM to inject the main fuel shot, OR does the IDM send only one signal to the injector and the pre shot & main fuel shot is just the normal basic function of the injector? I mean after reading all that I have read it seems once the injector is set into motion it is just a process the injector takes to fire one pre shot then the main shot of fuel??
Like I said I'm just trying to stir some conversation to learn a little about the different types of injectors and WHY they are different and which is best............ Thanks for all the input so far guys.
Rob
