how to test the icp sensor
40K views 5 replies 3 participants last post by  Mhatlen
#1 ·
Is there anyway to test the icp sensor my truck won't start when warm read on another thread the icp fixed the same problem just want to test before spending another 150 on the truck thanks for any help
#2 ·
Have you unplugged it to see if it starts?
Do you have gauges to see what your (ICP) hpo pressure is?
Is it leaking oil?
It's a variable resistance pressure switch, not sure what it reads static, do you have a ohm meter? If so I will pull my plug and read it across the terminals for a comparison......
#4 ·
I will go take a reading on mine, be back in a few.....
#6 ·
Resistance across the two pins straight across is 6.56
From lower left to single is 196.4
From lower right to single is 190.5
These are engine cold not running.
ICP Voltage at koeo 1.0
625 rpm 1.8
Range 0.15-4.7 volts
Have you tried to start unplugged ?
