Hey guys and gals, i had another thread going about problems i was having with my truck, but it got really confusing to me and wanted to start over with the problems im dealing with now, and hope to correct them.
So right now, Ive got a 3" DP with no exhaust, Wicked Wheel 2, custom e-Fuel setup, K&N intake system, and RiffRaff Bellowed up-pipes and intake boots, with PHP Hydra and Swamps tuning on it. The truck is a 96', F350 SRW, CCLB, with 4.10 gears, and 352k miles on it, with AA Code injectors. (Unknown how old injectors, hpop, ipr, icp, turbo or anything like that is).
When unloaded, in any weather condition, if i put my foot to the floor, i can pin my Pyrometer at 1500* in a matter of seconds. Dave at swamps pulled fuel out of my tunes and it made no difference but made it slower.
So i hunted for exhaust leaks, and found a big one at driver side manifold, had it fixed, and now have no exhaust leaks. And when i went to install my wicked wheel 2 last week, i saw the o-ring at the intake spyder was split in 2, so i got a new one from ford, and put it in. Im 99% sure i have no intake leaks post-turbo, but i will do a boost leak-test tomorrow.
Now over the last week or so, ive noticed the truck getting tired, slowing down, etc. and checking ICP pressure, in "Hot Street" mode on the tuner, in 4th on the freeway, it spikes to about 2400psi, and then drops to 1840 before it stabilizes. Could this be a worn out hpop, bad IPR valve, or bad injectors? Im not sure.
I did climb a 6% grade last week with 5k lbs trailer behind me, and was able to maintain 62mph in "Heavy Tow" tune, with it right at 1250*, in 3rd gear and was at about 90% pedal. If i put it to the floor, RPMs would shoot up, the truck would start to take off, and could easily get up to 75+mph, but EGT's would peg 1500* instantaneously, so i let off almost as quick as i got into it.
Now what needs to be my first step in diagnosing this problem i have, im really leaning towards a t500 pump from terminator. I have a spare HPOP with IPR sitting in my garage that i think i want to send to him and get done, but if its not necessary right now, well, then i dont want to do it unless i have to.
Thanks guys, your the best!
Daniel
Daniel
