HUEI is a much more involved system. They dont fire as fast as a common rail but thats due to there design. You can have multiple injection events but the precision and timming of those is what lacks and why ford made a switch to CR technology. You gotta recall....from 03-07 ford used one engine with minor tweeks and was able to remain EPA complient. All of the newer technology is to assist with emissions and noise. HUEI injection pressure is still around 29,000 PSI so its close to common rail pressure, but the CR's are a much differnet designed injector. Since the fuel is pressurized its a simple open/close of the injector...With HUEI its the same way but you need oil to do the work opposed to the injection pump. Weather its better or not is debatable, it depends upon your outlook. I will say they are more efficent of a system in general, but they all still have drawbacks.
