HELP HELP HELP
1.5K views 16 replies 6 participants last post by  miller45103
#1 ·
Have a 2004 F350 with only 57k miles. Last weekend I towed my camper from Baltimore to Virginia problem free. After dropping the camper I ran out to get some supplies. As i pulled out of a parking lot my truck began to run like crap. Sluggish, RPM's really wouldnt go up past 1500, kinda felt like a dead miss. Stopped at Napa and bought fuel filters, replaced both and it ran perfect. Drove 2 hours back home empty and it ran great. It sat for a week, went out today and started it, it had the same dead miss, ran like crap. It seemed real lopey, no smoke, no CEL. Went and picked up a set of Motorcraft filters. Changed them again, didnt see any visual dirt, discoloraton or blockage. Again, it cleared right up, ran like new. Come home and parked, ate dinner, went out for a test drive and same BS again. The truck sits a lot, in my garage. I am puzzled here. Any ideas?????
#5 ·
the part is less than 200 bucks. probably around 180. im not positive but 5/04 is probably early enough to be the early style engine. that a good thing cuz they are the good ones in a lot of ways! the bad news is that if its an 03 type engine, the icp sensor is not fun to change. its not impossible, just not fun. if it is an early engijne, the icp sensor is back behind the ipr, in the pump cover. if its a late o4, the icp is in sticking through the passenger valve cover near the glow plug module.
#6 ·
You really need to scan it and see what codes you have first.
#8 ·
Most codes do not turn the CEL on, only emission related and misfires above a certain percentage turn the CEL on.
#11 ·
Well, I think Ive got this thing licked. I was under my truck poking around. The plug in the back of the fuel pump is missing the little tab that holds it on and the black wire going into the backside of the plug looks effed up. I started the truck and pulled that plug off and it ran like noted in my first post. I'd wiggle it some more and it would run good. Im going to Ford tomorrow and geting a new plug. I sure the lleh hope this fixes my problem.
#14 ·
Do you have stock injectors? Or aftermarket?
sent from my smart car
#16 ·
Well, got this issue licked. The plug going to the back of the pump (12 volt I assume) had a broke clip which made for a real loose connection. Upon inspection of the plug one of the terminals was burnt. Went to ford, got the new plug (36.00 WTF) and what do you know.......problem solved. Guess it would explain changing the filters (bumping the plug) made it run better. Injectors seem to be ok. No smoke, starts fine.
