My truck is a 99' so it has the headlight harness for a 9007 bulb from the factory. Since I did an 05' conversion I have a headlight harness that plugs into the 05' h13 bulbs, and plugs into the factory harness for the 9007 bulbs.
So the factory harness only triggers the relays for the h13 harness (or 05' headlight conversion harness) to turn on the lamps.
Now my question is can I get h13 hids for the 05' lamps with a harness that plugs into the factory 99' 9007 bulb harness? I'm wondering because if so, that means I can simply eliminate the 99' - 05' headlight conversion harness correct?
Sorry for over complicating, just wanted to be clear. :doh:
