Don't buy from db electrical !!
12K views 41 replies 23 participants last post by  JLDickmon
#1 ·
Purchased 2 of their heavy duty starters and an alternator...
The first starter went bad in a year..called, emailed..no response..
Second starter went bad two weeks later...called, emailed, no response..
Left a nasty message and a nasty email...got an email back to call so and so at this number....
They then told me its been just over a year, our warranty is a year, we didn't get any of your messages, your sh*t out of luck basically...we don't care that you spent money with our company, we are only worried about the new money, if you want you can ship the 2 20 lb starters to us at your cost and we can quote you some prices to fix them....why wold I want to try and fix the things that were supposed to be heavy duty, high torque, beefed up starters..that only lasted about 10k miles and after I had to beat them with a 4lb hammer to get one last kick out of them..
Talk about not standing behind your product...
I asked to speak to a manager...they are all in a customer service meeting...ha, was that a joke?
I then told them like many others these days I found their company via online automotive forums, and I would proceed to go back to all of those same forums with millions of active users and tell them how I made out with my db electrical starters...the guys response...(no offense to anyone as I'm from the NE, haha) in an almost fake sounding Jeff foxworthy impression voice hep said..I don't really cares about any of that, I don't use the emails.
So am I wrong and a starter should only last a year or in this case..10k miles..?.
#2 ·
that sucks a couple years ago they were suppose to be gtg for starters atleast.
#3 ·
Hard to say. Some people say they have problems with them, I personally have had no problems at all with mine. I installed mine April 1st 2008 so its a little over 2 years old now. No problems at all.
As for warranty it has a 1 year warranty. If its past that point then its time to buy another starter when it fails. You have to decide if it got far enough past that 1 year warranty or not.
Also why did you buy 2 truck starters as your sig shows 1 truck and 1 car.
#5 ·
The only thing Ive run into that kills any starter that Ive ever had is mud. I dont mean the think stuff I mean water with dirt in it aka the stuff in mud holes. When that gets in a starter its a death sentence for it eventually.
The db starters are not some magic pill its a nipon denso or a clone of one with an electric motor and a gear reduction box. You can get one elsewhere but its around $400+ dollars for it. With the price from db being $135 or something with cheap shipping its around 1/4 of the price of the other so you need to go thru 4 of them to equal the price of the other. But with that said if its failing every year its not worth buying I guess.
Though like I said mines over 2 years old and cranks great. I offroad with my truck but I havent filled the starter with mud either so maybe thats why its lasting. No clue.
If hitting it makes it work as in it doesnt even click till you hit it you either have a bad solenoid not the starter itself or a ground issue.
#7 ·
You sure its not your batteries? My optima batteries did that and I put in a new set of batteries and its back spinning full speed. Thats with db starter I have.
Being gear reduction it doesnt behave like a normal starter when the batteries are weak. Sure it makes starting the truck hard or impossible but it acts more like the starters dragging than the batteries are weak when in fact its the batteries.
Not saying thats for sure your problem just a sugestion.
#10 ·
That is VERY true. I had a similar problem that turned out to be batteries - not the starter.
Sam
#8 ·
I would disagree with your opinion. If the warranty is 1 year - the warranty is 1 year. If they choose to extend it past that point, that is up to them. If you don't like it, go buy a cheap chinese crap that you have to swap every 2-3 months - but has a limited lifetime warranty.
I have their starter on the truck along with their alternator. I have had 7 of their high amp alternators on my various vehicles. I have only ever had a problem with 1. I emailed them and called them as instructed. They had me ship the alternator to them, diagnosed the problem, and told me the cost to repair as it was just out of warranty. I called and talked to them professionally and courteously - and guess what? They repaired it for free.
Sometimes when you act like a dick - you get what you deserve...
Sam
#11 ·
Seems like we started hearing about this a year or so ago. As mentioned, DB used to be the place to get starters / alternators. The guys there were top notch and always helpful. Seems like they changed to Chinese crap and peoples opinions of their products have been less than stellar recently.
#14 ·
Sam
That is probably what happened. I have had good luck with DB
#15 ·
Well we've seen it all before haven't we? Company A has good customer servide, great products and reasonable prices, time goes their product gets popular management thinks well what the hey we can probably make more money if we can lower production cost! The result is usually what we se now.
I was planning on buying a new starter and alt from them, but it seems I'll have to look elswhere unless this is just a localized phenomenon.
#16 ·
If I need an alt or starter I will be buying from db again personally.
Mines done great so until I have a bad experience personally I'll get buying from them.
#20 ·
I bought a DB electrical alternator and the outer casing had cracked within 8 months. I called them and they replaced it. The replacement only lasted 1 1/2 years and crapped out. I went to my local starter alternator rebuilding shop and bought a new alternator and it just so happens to be the exact same manufacturer of the one DB sent me the second go round. Since DB or the rebuilding shop did not ask for a core I dropped one of my bad ones off at the rebuilding shop to get rebuilt so now I have a backup.
#21 ·
Personally, I have been less than satisfied with DB's products and service.
To date I've purchased three alternators and a starter from them, and I've had issues with all three alternators.
The first alternator crapped out after two and a half years. I figured no big deal, and purchased a new one from them, as the broken one was out of warranty. At the same time, I also purchased a spare to have on hand in case I had another issue.
The voltage regulator in the second DB alternator died right at 13 months. I contacted DB and paid them to fix the voltage regulator.
Fortunately, or so I thought, I had the spare alt. I took it out of the box, and installed it only to find that it didn't work (another bad voltage reg). I called DB and told them that my NIB alt did not work. They told me that even though it had never been used, it was out of warranty, and that I would have to pay to have it repaired.
So, I suppose there are two ways to look at this. One way is: I guess I should have checked the spare alt when it originally showed up to make sure it worked. But, on the other hand: I think a bad voltage reg would have been evident to the guys at DB before it was ever sold. To me this screams a lack of quality control on their part. So, it is very disappointing that they would not stand behind their product. Afterall, I think every sponsor on this site would stand behind a NIB product even if it was out of waranty.
Anyways, I've had enough problems with DB Electrical, and will never purchase anything from them again.
#22 ·
All of there products come from CHINA. Thats why it's so cheap.
#25 ·
My thoughts.
My starter took a dump on me in O'Reilly's parking lot (pretty good luck, huh). Bought an O'Reilly's rebuilt starter, the guy load tested it for me before install. Pulled two out, took the strongest one. Been on my truck for around 75K now, still going strong.
Water pump went out. Replaced with O'Reillys rebuilt water pump. Been on my truck working good for about 50K now.
Alternator went out. Limped to O'Reilly's. Bought a rebuilt unit, installed and load tested in the parking lot, it was weak. Installed and tested another one, good and strong. Been on my truck for about 50K.
All of these parts are lifetime warranty. If one breaks, I take it to O'Reillys, swap it for a new one, no questions asked. I am back on the road in the same day.
If you buy a simple part from the best shop, with the best customer service, but they have to ship it to you. You are sown for at least two days, probably more.
I don't know about you, but I need my truck running. A day down, put me and people that depend on me in a bad situation.
#26 ·
I've installed around 12 DB gear reduction starters and 1 alternator over the past ~3 years.
I've only had to send one starter back, and that was because the truck's owner was holding the key on start after the motor fired up, and he tore up the starter gear and his flexplate. DB sent me another starter no questions asked.
I know what it's like to be on both ends of the phone when calling for warranty on a part. You get alot further if you're courteous and ask for something to be done. Demanding will get you nowhere fast.
Dave
#30 ·
I always take mine to a local rebuilder, who does great work. Normally in and out in 1hour. I have never had to take a single thing back to him for repair. Price just doesn't even compare to replaceing them. Guess I'm lucky to have one close.
#31 ·
Hmm thats strange I cant find my starter on there anywhere. All of those look like the junk autozone sells.
Heres what I bought :
Its the black and grey one :D
