Got the ceramic coated up pipes from DI and need to decide if the 4" downpipe has to come out to access the manifold flange.
I got the manifold flange bolts off the driver side and the bottom one on the passenger but the top one is tough to access. I got it loose but not out.
I removed the clamps on my exhaust but I think I am going to have to heat the slip joints to get the downpipe loose from the rest.
If I remove the crossmember can I lower the downpipe enough to get at the problem?
Either the downpipe has to come out or I cut a small hole in the plastic inner fender to get to the bolt head for this to work. Then I still might not be able to snake the DI up pipes in with the downpipe still there.
Am I missing a third option or an easier way to get the up pipe out of the way?
Thanks
Thanks
