Please go easy on me, I did search the codes both here and on Google, I saw posts on the P0730 code with other codes but not with the P2701 specifically. That being said, I know what the codes mean but I do not know if I have an "easy" option to try or if the transmission is toast. This is my only vehicle, it's parked, and I'm in a bad situation....
I have an '03 F250 FX4, 6.0, with an '08 transmission. The problem initially started out as very soft shifts all through the gears then progressed to just revving on 1st to 2nd shift, all other shifts were erratic and going down the highway it would slip in and out of OD. Now it is shifting hard from 1st to 2nd, slow to make all other shifts, and will not shift into OD at all. Transmission fluid is on the full mark, looks perfect, and doesn't smell burnt. Obviously the tow/haul light is flashing on the shifter.... I do have a Edge Juice w/Attitude "tuner" that was on the truck when I got the truck 4 years ago and I never run it in "race" or "extreme" tunes. I've ran the "drive" tune since I got the truck and my buddy had just installed the transmission so I do not know the mileage on it, the "tuner" is mainly used for monitoring and for the turbo timer to cool down the turbo before the engine shuts off.
Just for reference, code definitions are:
P2701 - Transmission OD solenoid is sticking on or off intermittently.
P0730 - Incorrect gear ratio.
Where do I go from here? Is the OD solenoid located in the transmission or elsewhere and could it be the cause of the P0730 code? I truly appreciate any useful advice y'all can give.....
