Ok, I have a question on where to install the boost gauge hose. I have heard about this "T" to rid in to the map sensor. What are the materials needed to make this T? Or is there another place?
The Y-pipe or spider is what is right in front of the turbo. A clamp holds it onto the turbo, and then there are 2 hoses off the bottom that hold it to the intakes.
Take it off the truck, drill/tap and put your fitting on. They reinstall it on the truck an hook up your gauge line
not saying anybody is right or wrong but doesnt the y pipe read alot more boost than it is actually getting? cause 32 pounds on a stock turbo is a little much?^
I have mine spliced into the MAP sensor line, and when I have my boost leaks and up-pipe leaks sealed up it makes 38 psi on a stock 310k mile turbo. With the leaks it still makes 34-35 psi. This is with 150cc Swamps injectors. Once I add my intercooler I plan to tap in a couple of spots (pre and post IC) to measure both pressure and temperature.
Regards,
Michael Pliska
posts
2.5M
members
113K
Since
2007
