Tarm, No problem, wasn't trying to put you down for your way of looking at filtration. The bad thing about forums and internet communications is thyat it is easy to misinterpret someones tone.
For the O.P. you seemed receptive to other alternatives and $$ seemed to be a factor in decideing wich system you were looking at.
This was taken from OilGuards web site and goes back to 2001 time frame.
"No bypass or full-flow filter currently available,
including OilGuard’s bypass filtration system,
can effectively remove any substantial amount of
sub-micron soot from engine oil.
Any manufacturer that claims their filter can provide nominal
sub-micron filtration is simply misleading consumers."
Modern oil manufactures blend in additive packages that contain dispersants. One of the functions of a dispersant is to keep sub-micron soot particles in suspension and separated from each other.
As mileage or hours on an engine’s oil increases, additives become depleted, their ability to prevent sub-micron soot particles from bonding together decreases. Eventually sub-micron soot particles begin to bond (agglomerate) and grow in size. Once a soot particle grows to 1 micron, the OilGuard bypass filter will effectively trap it. This process is how OilGuard filters soot and helps to "control" soot at an acceptable level to support extended oil drain intervals.
Filtration aimed at removing any particle below one micron is excessive. The tightest clearance used in an engine is 3 microns, bearing and valve clearances from 8 to 35 micron, and piston clearances from 35 to 100 microns.
Claims of nominally filtering out sub-micron soot particles are impossible given current filter mediums (cotton, paper and glass). While striving for this goal may seem admirable, one must look at what damage would result if such claims were true.
Properly functioning additives suspend contaminants by encapsulating sub-micron particles. In order to filter out these sub-micron particles, the additives surrounding the particle would also have to be trapped. Trapping additives inside a filter means that the oil remaining in an engine's system will have fewer additives available to protect components thereby increasing the probability of engine damage.
Based on the above comments regarding soot I can expect my oil to get darker, maybe even black, due to the SUB-MICRON soot particles. However, these particles will be removed once they reach 1 micron and no damage will be done to the engine. The other interesting thing is that the oil flow rate with the OilGuard is 1.5 qts/min. What kind of flow rates do the other bypass filters have?
