And yes I have read the “Newbies looking for more power” thread…
I have a ’01 7.3L F250 4x4 automatic with appx. 190,000 miles. The auto tranny is on its second rebuild, the first time it was done under Ford warranty and the second time was by a local shop and I do not know what parts were used. I have had the truck since new and it has stock head bolts etc.
The truck’s main purpose is to tow a 8,000 lb wakeboard boat around to different NorCal lakes, tow teenagers to the local movie house and occasionally tow a 18,000 lb excavator (very rarely as I have a couple of F550s and a Dodge 3500)
I had a different turbo installed years ago, it is a Garrett, but I don’t remember anything other than it is a “ball bearing” model (GTP38R?)
The motor has a cold air intake and a 4” exhaust.
I also had installed an Edge (Evolution?) tuner (model #?)
I run around with my Edge Tuner on “5” and it doesn’t seem to make any difference if I have it set on “1” or “5”. The tuner is left plugged in all the time.
I have decided to keep the truck and am adding some 35x12.50/20s along with a 4” lift still running the factory 3.73s.
Now after too many PSN threads and hours of reading, I am confused about the difference between a “Tuner” and a “Chip”
My Edge is connected to the OBD port full time, what is it doing different than a chip does?
Would I see a difference with going to a “Chip” with a “Custom Tune”?
I have been looking at the TW custom chips, dp tuner, Diesel Innovations websites and have been down a bunch of rabbit holes not exactly what I am looking at.
And what parts do I need if I do?
Where does the “Chip” mount/install?
Do you mount a rotary knob inside on the dash within the driver’s reach?
Do the $500 +/- chips come with the six (or so) different custom “tunes”?
On the DP tuner site, what is the INFINITY-DX Touch Screen 7.3L? They call it a programmer???
Does the Pre-Loaded F6 1-16 Position switch on the fly SMARTChip come with the tunes? (Seems like it)
I have a pretty much stock engine, and use the truck as previously stated, is there some other engine mods I should do first considering the truck’s mileage? I am not looking for a race truck, but I do like power and I am tired of the 6.7Ls pulling away from me when they are loaded down and towing!
Thanks for any help…
