I bought a 2000 F250 7.3 with 129K. One owner, perfect condition. Only problem was that it didn't run. Got it home, cranked and cranked and it finally ran. Just had air in the oil system. Ran really well until I powerwashed the top and underside of the truck to get a bunch of gunk off it. Right after pulling out of the wash station, the truck began to run like garbage. To the floor I was only doing 15-20 mph and blowing white smoke. Had to pull over several times on the 3 mile drive back home. Did some research and learned about the wiring harnesses that connect to the valve covers and the UVCWH. Disconnected all of that and put high pressure air to it. All dry. Still had the issue. Checked all connections on the UVCWH, those were good. So I went to the injectors, when idling it sounded like it was missing. I unplugged injector 1 and nothing changed. I unplugged injector 2 and it sounded even worse. So I thought, must be an injector but I couldn't confirm as no local shop can test an injector out of truck. I bought the AE scanner and I did a buzz test. All 8 injectors buzz but cylinder 1 failed I decided to unplug cylinder 3 and plug injector 1 into the cylinder 3 injector plug but cylinder 3 didn't fail so the injector is good?? I unplugged the UVCWH for cylinder 1, 3, 5, 7 and did another buzz test. I heard 8 buzzes but cylinder 1 fails. WTF?? I started thinking IDM so I unplugged that, cleaned it all out and put it back. Run another buzz test and cylinder 1 and 3 fail now. My brain had enough confusion for the day so I called it quits. What the heck is going on with this thing?? I know it's something electrical and I know the UVCWH is working properly and that the injectors are fine. I really don't want to waste $250 on a reman IDM only to find out it wasn't the issue. Anyone ever experienced electrical gremlins on a 7.3L?
