Does anyone have any piston recomendations for building a performance motor?? I have the rods mainstuds/girtle all handled but dont know what to do about pistons/rings. May be the stockers will hold up?????
With ceramic coating you're virtually eliminating the worry about EGT's.
Do more research before spending the time and money ... that's all I'm saying.The cermaic coating does insulate the top of the piston, but its just insulation. Insulation in the real world only SLOWS the heat transfer to/or from an object. Ceramic coatings help, but pistons can definately still crack when running high EGTs. When I rebuild my motor I plan on changing to a steel piston just to try an avoid this very problem. I thought Mahle was working on just that, a steel piston with a keystone ring land that would work for a DD. If they are not getting ready to make one, or just aren't available at the time, then I will probably just put in Arias pistons since mine doesn't see any street use. Plus the ring lands are lower allowing for more radical valve reliefs and more wild combustion chamber designs than just "opening it up".
-Note: I do not feel that we need more valve releifs than what can be currently had. I just wanted to clarify that because someone will jump my case since the intake runner is the limiting factor in flow.....
