First post here. I have a 1989 F250 with a 7.3 IDI, 5 speed, 4x4. I recently installed reman injectors from Dieselogic.com. Before installing them, I cleaned the fuel tanks out and replaced the fuel filter. After install, I could not get the truck to start after a very long time cranking it. I gave it a shot of starter fluid and it fired up. Once the RPMs dropped, the truck started shaking really bad and the exhaust note sounded like it had a misfire. I cracked the fuel lines and bled the air out (I have done this several times now). I played with the injector timing some with no change. I saw on here that the fuel pump could be bad so I replaced that, no change. Driving around, it is very down on power and tries to die (and sometimes does). Now I have been fighting this for a couple weeks, still have to start it with starter fluid and still shaking violently. Any ideas on what could be going on? Thanks in advance.
