6.0 injector hold down bolts broken
14K views 19 replies 7 participants last post by  lenzhotrod
#1 ·
I talked to a guy today that had injector problems. He had installed alliantepower injectors about 7 ninths ago. He started having problems and checked the injectors to find out that seven of the hold down bolts were broken.
What would cause this.
#6 ·
over torque will not cause them to break instantly, if they are on the verge of breaking then they will hold for some time then start to give after time from the molecular structure of the metal deteriorating from the vibration caused by the engine
#8 ·
Shouldnt need them. Stock ones hold just fine.
#15 ·
very good reference to factory ford spec, i know elite torques theres to 36ft lbs, but are using a different style copper washer i beleive.... mine are torqued to 32 ft lbs to deal with high cylinder pressures than factory level.... we will see what happens
#16 ·
Actually the late year model (Jan-06 to 07) injector hold downs have a Ford spec of 26 ft-lbs (I forget what TSB it is in, but it is in the WSM also). Many techs are torquing to 28 ft-lbs and have had no problems.
#17 ·
Yea I did one set of Elite's. I read the paper and it said 36 ft lbs so I threw it away and laughed... I then looked at the copper washer and it was twice the thickness of stock.... I was like 'ohhhh'
#19 ·
I wondered how that would effect things.
