I am no speed typist so I will keep this SHORT. Recently, my ebpv starting drooling oil and since I wanted to"disarm" it I scratched my head for awhile one evening thinking of a way to plug it. I needed to plug off the hole for the armiture so I used a fine thread 7/16 nut and bolt with "felt" washers.With that clamping force it will not leak again in my lifetime.My big concern was the oil that would continously come out of the small hole (in the bottom of the chamber from the pressurized inlet). This constant stream of oil that runs down to the end of the chamber to the drain line would ALWAYS lower the pressure of the oil going to my turbo bearing-thats why I didn't like the "gut it and plug the armiture hole" method. It needed more mods. So here is how you plug the inlet hole coming into the chamber and at the same time plug the hole leading to the pcm controlled switch AND stop ANY OIL FROM ENTERING THE CHAMBER. If you take a 1 3/4 inch freeze plug and seat it in the chamber approximately a half inch from the entrance it will seal off these holes so you will have full flow to the turbo bearing all of the time.you also can leave the solenoid plugged in and not get any codes come up.With both holes plugged oil can not flow backwards out of the solenoid (taking away from the bearing lubrication) when it is activated. That happens when you only plug the small hole that puts oil in the chamber and not plug the small rectangular hole leading to solenoid. My method costs practically nothing and probably could be done without removing the pedestal from motor. I didn't try it that way because I had already removed the pedestal. BTW, if you sink the freeze plug too far...relax there is lots of chamber left just add another freeze plug and drive both in. How about we call it....... the Farber mod! ROTFLMAO!!!
