1 - 3 of 3 Posts
installed a new rebuilt zf5 47, this week new clutch, flywheel, prebkeed hydraulics, and new clutch pedal assembly with heim joint, any way. i only can shift into overdrive, trans wont go into any other gear. engine running or not, shifter is easy to install with new bushings, clutch feels great, any ideas, i dont see what i could of done wrong
i did,,,,,, the switch for back up lights didnt have a washer under it, screwed in to far and had the reverse shaft locked up, took on the switch shifts beautiful
1 - 3 of 3 Posts
