1 - 16 of 16 Posts
What is the best oil to use and I think I saw somewhere to park truck on a 4x4 to help over fill the trans any truth to that? Thanks
Is it low or are you replacing it?
I bought a used transmission and tcase so planning on draining and filling with fresh oil
Is it necessary to over fill it I just remember reading something along those lines somewhere. No advice on oil?
my 6th gear hates me so i run 140w? gear lube in mine, (really thick stuff) added i think it was 2gal but thats just what i did. others will chime in in a minute to better help ya
How does it shift with that thick of oil?
shifts normal to me, 6th still tends to scratch & kick out of gear but other then that i didnt notice any difference. neither good or bad
Doesn't it require synthetic ATF? I thought all these newer trannies had materials on the synchros that would be destroyed by old-school gear lube.
Former Ford Trans Engr.
Yes, you are correct, but a lot of people know better than the engineers that designed the transmission and run what they want to run.
There has been a change in the oil spec in the newer ZF6s. They are running some form of gear oil, I forget which. Google is your friend.
So, based on the advise of some people here, I am running 55-120 synthetic in my ZF6 and it shifts terrible. I'll go back to synthetic ATF like its supposed to have shortly.
Is this just a change in the spec, or is something internal (esp. synchros) different, calling for the different lube?
i think ill be doing the same here shotly also
I believe ZF recommends a Mercon V ATF and that the Ford spec references the same.
I'm using Redline D4 ATF. About 6 quarts I think.
Owners manual is available at motorcraftservice.com if you want to check.
1 - 16 of 16 Posts
