1 - 2 of 2 Posts
Fabricator/Mechanic
Discussion Starter #1 (Edited)
Question No.1
Is it possible to swap the 34spline input from a NVG273/5R110 to a 31spline NVG273/4R100 T-case? The NP205 series there is alot of different swaps that are possible between applications. found it here;
NV273 Transfer Case Parts Illustration and parts list, Ford Dodge! - Drivetrain.com
will it fit with out more parts?
Question No.2
Can the rear output from a ZF6/6.0 34spline be put in a ZF6/7.3 case? Anyone have any knowledge on this? thanx ahead, Andrew
To your first question yes it is possible and very easy to do. On the second question it can be done but it is a little more complicated than just switching rear outputs. They made a few changes between the ZF6 in a 7.3 and a ZF6 in a 6.0L. If you have any questions feel free to call me at 888-824-2012.
Dan
1 - 2 of 2 Posts
