1 - 4 of 4 Posts
BIG_RED
anyone know the gear ratios for gears 1 through 5 and 1 through 6 on these transmissions?
OD is actually HIGHER on the ZF5 than the ZF6
S42 ZF5
Close Ratio
1st Gear:
4.14
2nd Gear:
2.37
3rd Gear:
1.42
4th Gear:
1.00
5th Gear:
0.77
Rev Gear:
3.79
S47 ZF5
Close Ratio
1st Gear:
5.08
2nd Gear:
2.60
3rd Gear:
1.53
4th Gear:
1.00
5th Gear:
0.77
Rev Gear:
4.66
ZF6
Low:
5.79
1st Gear:
3.31
2ed Gear:
2.10
3rd Gear:
1.31
4th Gear:
1.00
5th Gear:
0.72
Rev Gear:
5.23
courtesy of diesel brad
S42 ZF5
5th Gear:
0.77
S47 ZF5
5th Gear:
0.77
ZF6
5th Gear:
0.72
While you are correct the number is higher, it is less overdrive. a zf5 at the same speed with run a higher rpm than a zf6. The zf6 has MORE overdrive, thus runs lower rpms at higher speeds.
sorry i just copy and pasted from a post a few months back and didnt think to reread the whole thing
1 - 4 of 4 Posts
