1 - 6 of 6 Posts
Anyone know if a Zf5 will bolt into a 99-03 and if the input shafts reach. I don't see why they wouldn't since it's the same motor but probably good to ask before picking one up. Yes I'm aware they are weaker than the 6
Sent from my SM-G930V using Tapatalk
Administrator
early 99's came with the ZF5. so yes they will bolt rite in. you may need a 5 speed crossmember though
  • Like
Reactions: testorossa1989
Thread Hijack!
What about the other way around? I have the ZF5 and would like to swap to a ZF6, as I have been told they are a stronger transmission.
Thoughts? Whatever I put in will be rebuilt before I put it in.
Thanks!
Administrator
yes. late 99's came with ZF6 trans.
Thanks, @tjctransport -
After all I have read, I will stick with the ZF5 since there just isn't that much to gain. Also, I don't want to bother with a transmission cooler.
Except that I have a ZF6, so I will stick with that! :D
1 - 6 of 6 Posts
