1 - 8 of 8 Posts
Diesel Man
I picked up a Zf5 from a guy on craigslist who said it worked fine, but there is something wrong with it. When I try to move the shifter over to the left like when going into 1st or 2nd it sometimes makes a sorta cracking noise and then is impossible to get into 1st or 2nd without going into another gear or letting the clutch out a little. It's def not the clutch pedal bushings, cuz it was doing this when I had it out of the truck. Once it is in gear though it works fine. Oh and also when the truck is running and I leave the clutch out in neutral the trans makes a horrible constant clanking noise and vibrates real bad. I can feel the vibrating up through the shift rod. I found a bunch of other posts that say this is due to me having a solid flywheel so I don't know what to think about that.
I don't know much about the inner workings of this trans, so does anyone have any idea where to start for trouble shooting this thing?
Me thinks it needs a rebuild.
You could try draining whatever crap fluid someone put in there, and put the correct stuff in.
Diesel Man
It had no fluid in it. I put new trans oil in it. It has brand new slave and master cylinder with new clutch fork and release bearing.
New trans oil? What exactly did you put in?
Rookie diesel tech
if it had no fluid in it then your synchros are probably shot are almost shot.
Diesel Man
I am assuming the guy I got it from didn't use it drained. He said he was going to put it in his one truck he had that was apart, but didn't have the time. So I would think he probably drained the fluid after taking it out of whatever truck he got it from.
1 - 8 of 8 Posts
