1 - 4 of 4 Posts
I had my ZF5 gone through about 3 years ago. I was told by the shop who did it to run regular ATF in it, and change the fluid once a year. So I have
The first year it was perfect, the second year, when it was cold out it was a bit stiffer on a 2-3 shift, and this year the 2-3 is a bit worse than last year again.
Was thinking if going to a red line or royal purple ATF might help this? Seems worse in cold weather for sure.. Was perfect all summer.
Or is there another type or brand of fluid I should try.
If this does not help I will probably send the tranny back in to be gone through next fall and change the clutch as it will be 5 years old.
Thanks so much!
Bob
Discussion Starter #2
No advice?..
Freak'n know it all
I run mobil 1 synthetic in my ZF6.... no way would I be changing every year tho unless pulling heavy and LOTS of miles
I actually kinda wondered if regular atf would let the syncros get a little more grip and make it shift easier..... it shifts quick n easy at low rpm's but wind it out and shifts take a while
I'm having good luck with Amsoil Signature Series Multi Vehicle ATF (red label/cap) have about 25,000 on it since August of last year hauling hot shot with a 43' 3 car trailer. Amsoil says it can go twice your manufacturer's severe service recommendation, but I'm about to change it again since I work my truck more than most.
1 - 4 of 4 Posts
