1 - 4 of 4 Posts
Went to pass a car last night 6th gear WOT and right when I got right beside the car trans went bang and then acted like it went to neutral. The truck will move still, but no more than a crawl in any gear no throttle. Clutch pedal still feels normal, no change. Anyone have any ideas?? One of my buddies thinks I busted the center of the clutch out but if I did that I would think it wouldnt move at all. Please HELP! :confused:
Road Hammer
What clutch is in there? If it moves at all in any gear I would look to the clutch/pressure plate first.
Im not sure what clutch is in it. The more I tried to move it it started sounding like a bearing would growl off and on. I wish this truck would just burn to the ground.
4x2 or 4x4? What do you mean by "no throttle"? Does the engine not rev up when you push the go-pedal? What does it do when you attempt to rev it up in neutral?
How's the tranny fluid level? How's the clutch fluid level?
1 - 4 of 4 Posts
