1 - 11 of 11 Posts
What are the differences other then overdrive or granny low that comes in the zf-6. Which is stronger? what are there weak points?
Crazy *******
This is from the gearvendors website.
http://gearvendors.com/f2wdt.html
Those are the trans ratios for the 5 and 6 speeds.
The 6 speed is rated higher input torque than the 5 speed. The biggest downfall of the 6 speed, I think is the split between 2nd and 3rd gears. JMHO
Marc
Ok. thank you. Looking at a 99 that has a 5 speed and was just wondering.
Must not be a PSD, all Super Duties have the ZF-6.
I have been around several 5's around the farm.....most of them you have to hold in reverse to keep it in, or they have an issue with 2nd gear.
I have had great luck with both of the SD ZF-6 tranny I have had. Done a lot of heavy towing with both trucks.
My early 99 has a ZF6. I have beat on it for years. I do not have any experience with the 5 speed.
All sds psds got the zf 6
Discussion Starter · #10 ·
Daily driver. I bought one last saturday. The automatic truck in my sig is prolly gonna be going up for sale soon.
i have a zf-5 and have always had a problem with 2nd to 3rd. fyi
1 - 11 of 11 Posts
