1 - 1 of 1 Posts
97 7.3 F-Super duty, oil in fuel bowl, will NOT crank without ether. Plug passenger side HPOP line, will crank and run on driver side bank. DO NOT tell me injectors or o-rings, they've been replaced. Truck is using about 1 qt. of oil per minute while idling, smoke will fill up shop. Turbo has been checked, no oil leakage into Y-pipe, oil fill cap off with engine running, very light blowby, really just a wisp, of vapor. Truck was running perfect, cut it off, 30 min. later got ready to leave, would not crank, used ether to crank and drive back to shop. Truck used 2 1/2 gal. of oil to drive 20 miles. Someone tell me, do I have a cracked head internally between fuel and oil rail, possible bad injector sleeve, I do not know, and neither does anyone else around my part of the country....
1 - 1 of 1 Posts
