1 - 6 of 6 Posts
I have a couple sources for wvo and was wondering if someone could give me the basics on the best way to run it in my 97 f250hd with the di 7.3. Thanks for the help
Discussion Starter #2
Also I was thinking about adding a separate pump and filter set up for the wvo to my efuel. Maybe front tank wvo rear tank straight diesel?
heated tank, heated filter, fuel temp going into heads at no less then 140 degrees Farenheit. Backflush the fuel line with diesel before shut down and thats about as down and dirty as it gets.
:whs:
There is a TON of information out there just do a little searching. Lots of companies making complete kits as well.
what about running 50-50 wvo and diesel (with filtered wvo)
Unless your in Southern California or Arizona, I don't think I would run anything more than a 20% WVO mix without a heated tank.
1 - 6 of 6 Posts
