1 - 5 of 5 Posts
Hey guys so i pulled the truck im selling into the shop this morning, it fired right up out side in the cold, let it warm up, drove it in, shut it off, changed a cab light and took the toolbox off and now when i turn the key the wts light doesnt come on but the ovrdrive light in the shifter is on.. The guy who bought it is comming in an hour or two so i need help asap. hopefully its just a fuse but which one?
ps it an early 99
I would start with fuses. Not sure which one. Maybe somebody else will know. You could just start pulling one at a time to check. Good luck.
All done now
Was it the fuel heater/PCM fuse. If so, unplug the fuel heater. If you don't, it will blow again. Mine has been unplugged for three years with no issues.
it was a 30amp fuse, dont know the number and cant check right now but i believe it was the only 30 in there. in cab, bottom fuse i think second row in from the right... if that helps?
1 - 5 of 5 Posts
