1 - 9 of 9 Posts
need a good set of up pipes for an e99 i think i can use late 99 also just have to cut them down. Thanks Brad
STILL LEARNING
I actually have 2 set of used ones. They show a little wear but neither set leaked. One set has been sandblasted and coated with HI temp Eastwood Manifold paint.
PM me if interested
I like turtles
You are correct. You can use later but will need to trim one down. Also a trick I learned on here is if there is a lot of wear on the end. Cut off a couple inches. Flip it and weld it back on. Will give you a virgin surface.
Why not bellowed up pipes??? Just curious. I am trying to figure out what the advantages and disadvantages are.
thanks
1 - 9 of 9 Posts
