I need an OBS 40/20/40 prefer in grey. I need seats track and all.
If anyone has one or knows of one please let me know.
Thanks,
Paul
Thanks,
Paul
Thanks MarcPaul,
I will have to look at the set that I have in the parts truck. I don't remember the condition, but I will get back to you in a day or two.
Marc
Thanks but I'd rather have the original OBS inti put a 99 seat and brackets in a 94 and a 97 truck i had didn't know if you have looked into that or not just a thought
If pauls not interested, I amI have gray 40/20/40 seats out of a 95 extended cab. Which means you'd have to drill a few more holes. They could use a good cleaning, but are in good shape. And aren't you in TX?
Correct if you go the direction you went. From a reg cab to extended cab. However, 40/20/40 seats that CAME in an extended cab have a whole different set of mounting points instead of just the 4 bolt bracket that reg cabs and crew cabs have. Ex cab seats all bolt in separately.They should work in either a reg cab or extended without drilling more holes. I replaced the bench in my ext. cab with a 40/20/40 from a reg cab and it bolted right up without any issues.
