1 - 7 of 7 Posts
aluminum fab
Discussion Starter #1 (Edited)
Im looking for some knuckles and spindles off a ball joint 60, NON unit bearing Pre superduty. 92-97 will work though id prefer 95-97 with the bolt on calipers. If you have spindles, Id probably take those too. Let me know what you got. thanks.
edit: can this please be moved to Engine/Drivetrain. Thanks.
Where are you at?
I have a pair of '92 knuckles. Shipping could be prohibitive though.
Also have D50 spindles which will work on the balljoint D60s.
I understand that D50 spindles are different. The difference is the D60 spindles have a thicker shoulder on the backside and it's more than "just a hair". It doesn't matter with balljoint knuckles because there isn't the thickness of a brake caliper bracket that they also have to go through.
Been there, done that as my balljoint D60 has D50 spindles. You can't do that on the kingpin D60s, but you can on balljoint D60s.
1 - 7 of 7 Posts
